Re: 560 diesel - rebuild roosa master pump
Posted by Allan In NE on July 14, 2009 at 05:39:35 from (148.78.100.117):
In Reply to: 560 diesel - rebuild roosa master pump posted by Tractordummy on July 13, 2009 at 12:40:50:
Don't forget to FIRST pull the little timing window cover and turn the engine until the marks line up.
If you don't it would be the same as yanking a distributor without noting the rotor position.
Allan
