Posted by Wardner on July 14, 2009 at 09:53:11 from (4.154.243.225):
In Reply to: Farmall 350 or 300 posted by Todd A Poor on July 14, 2009 at 04:47:36:
I don't own a 300 or 350 but I assume the some of the differences on a 400 and 450 will apply.
The steering wheel is the easiest tip off. 400 uses a M type keyed wheel. 450 uses a splined wheel. There is more plastic on the later wheels. There is also a 3 inch plastic "horn button" on the 400.
The cowl on a 450 has several holes for switching from single to double acting hydraulics. On a 400, the right side hood has to come off to make the switch.
I don't place much faith in casting numbers. IH stockpiled many castings for six months or more. All they are good for is to indicate that a tractor could not have been assembled before the last date. In some cases, that won't even work as parts could have been replaced due to some failure.
Isn't there also a displacement increase on the 350? That number will be cast into the block above the oil filter.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
