D-239 injector pump
Posted by Bill Allis on July 14, 2009 at 11:14:30 from (74.78.247.18):
The 574 is still a one hour tractor. I've tried the simple stuff, drained and strained the fuel tank, new hose, it only skips under a load so I can't fool with the injectors.
I understand there is a fuel pump built into that Bosch injector pump and it has been suggested that it takes about an hour of load to warm things up enough for the seals and etc. to start leaking. It did not cool off enough in 45 min. to run without missing.
What do you think?????
