first suspect is the in line filter. pull the filter and see if it has any crud in it. also, it may be a fuel filter for a pressurized fuel system, not a gravity flow. if you are going to run an inline, try a napa 3032 or 3031 filter, depending on the size of your fuel line. check your fuel flow at the carb to be sure you are getting enough. from there , i would look to air cleaner for debris, possibly a mouse nest or mud dauber wasps. if thats all good, look to the ignition coil or condenser.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
