Re: Belt Pulley ID Help?
Posted by tld nc on July 14, 2009 at 15:47:52 from (75.177.72.195):
In Reply to: Belt Pulley ID Help? posted by Kendog on July 14, 2009 at 12:00:18:
It appears to be for a Ferguson or Ford tractor. If the opening for the pto shaft is 1-1/8 inch diameter it will fit a TO-20 Ferguson or an 8N Ford. If the opening is 1-3/8 diameter it will fit MF 35, MF 135, Ford 601 and up thru 3000. It may also fit others.
