I have also had a ring of organic debris floating around in the fuel tank, occasionally plugging the sediment bowl inlet. It was very hard to track down.
The solution is to check the tractor quickly when it dies. Immediately pull the carburetor drain plug and see if it still has pleanty of gas. If it has gas, see if it has spark. You may have a coil or condenser getting an open circuit when it gets hot, and 20 minutes is about right. As soon as it cools down it will run again, so check it immediately after it dies.
I have never had trouble with an inline fuel filter on a gravity fed Farmall but have had several instances of plugging inside the fuel tank. I have also had condensers and coils go bad only when hot. I almost killed a hired hand one time, he was brush hogging and thought he killed a crank start A. He cranked on it until the condenser in the magneto cooled down and it would start, on a 100 degree day. He was a lot more of a man than me.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
