Re: M diesel engine
Posted by Andy Martin on July 14, 2009 at 16:08:32 from (199.197.2.145):
In Reply to: Re: M diesel engine posted by Nathon on July 14, 2009 at 14:05:23:
Well, it's dieseling. It will quit when you shut it off :-)
They all rattle a little, of course.
Now if you have had the tractor for some time and it didn't make the sound you are hearing before the rebuild you may have a problem. It would be good to try to find another diesel M and listen to it run, maybe at a show if you don't have any neighbors with one.
