Re: cub noise
Posted by john *.?-!.* cub owner on July 14, 2009 at 19:41:04 from (72.161.140.229):
In Reply to: cub noise posted by don hinckle on July 14, 2009 at 18:57:01:
difficult to tell without hearing it, but cubs use square cut gears, so whines of varying degrees are common in them. Frequently different depending on what gear you are in.
