Re: Sweaty Carb
Posted by pete 23 on July 14, 2009 at 20:32:16 from (173.87.14.132):
In Reply to: Re: Sweaty Carb posted by H. Springs on July 14, 2009 at 19:16:36:
If you kept engine running with a hair drier, this may well indicate your heat riser is not functioning. Weak spring, stuck shaft, burned out plate or just crudded up with carbon on inside passages surrounding intake manifold. Have not seen any problems with ethanol mix in these parts. If shutting down for a few minutes helps it is eiether freezing up inside or you don't have enough gas flow into carb, unless you have an igniton problem but does not sound that way to me. Up north here we have a lot of these kind of problems when using left over winter blend gasoline. Wouldn't know about your part of the country.
