Re: farmall m clutch
Posted by mkirsch on July 15, 2009 at 09:34:05 from (64.80.108.57):
In Reply to: farmall m clutch posted by chickenfarmer on July 15, 2009 at 08:30:16:
You can replace the clutch and pressure plate through the bottom of the tractor after you remove the liftall. The hardest part is wiggling the front half of the input shaft past the back half once you get them separated.
Of course if you burned up the clutch the flywheel may need to be turned. That will require a split.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
