Re: SMTA SHift lever
Posted by pete 23 on July 15, 2009 at 10:32:40 from (173.87.14.132):
In Reply to: SMTA SHift lever posted by GordoSD on July 12, 2009 at 08:12:07:
Revisited this question again, just want to say I replaced several of the shift towers on 4 and 560 tractors when they were new as they went to an o-ring seal under the spring and a vent in the tower itself to help keep water out . This was done during installing final drive improvement packages. Well, these holes WERE NOT egg shaped. Not perfectly tight but very little up and down movement. Up and down movement allows the end of shift lever to crawl out of notch in fork and wear end of lever. Been there, done that.
