Re: Removing Flex Coupling
Posted by Janicholson on July 15, 2009 at 12:28:42 from (199.17.6.90):
In Reply to: Re: Removing Flex Coupling posted by David Goode on July 15, 2009 at 11:34:51:
If there are three holes in the pressure plate, around the rear edge of the metal where the levers are attached, These can be used with three of the PP bolts (taken out at 120degrees apart) to compress the clutch springs. this allows much more wiggle room for snaking the shaft out. It does come out, it is just a geometric issue. JimN
