Re: spark farmall H 52
Posted by Janicholson on July 15, 2009 at 12:59:23 from (199.17.6.90):
In Reply to: spark farmall H 52 posted by Matt southard on July 14, 2009 at 17:16:46:
Put a piece of plastic in between the points, and see if there is voltage at the connection on the side of the distributor. If there is not, the insulator where the points connect is not doing its job, or the condenser is shorted, or a lead is pinched to ground. a hot coil is sure to be on. if it is on for five minutes without running it should be warm to hot. They are not intended to be on W/O running. JimN
