Re: Using old IH tractors...
Posted by Logger on July 15, 2009 at 13:39:18 from (71.181.255.208):
In Reply to: Using old IH tractors... posted by Dave H (MI) on July 15, 2009 at 08:34:20:
If you are already damp in your area, don't do no till. Holds a lot of moisture in, but that could work against you if you live in a wet area. Farmers planted for many years plowing and disking (we do potatoes, so we always will plow.) and it still works well. Work with what equipment you got, as it seems to be more hobby than anything else. I use an old two row IH planter for my corn. I'd kill the grass in fall, then plow it under as deep as you can. That will rot much of it. When the weeds poke out in spring before planting, kill it again, then plant.
