Re: How did they lock out 5th gear in the steel wheel tra...
Posted by Crazy Red Power in SE-WI on July 15, 2009 at 17:26:25 from (24.183.138.183):
In Reply to: How did they lock out 5th gear in the steel wheel tractors? posted by sflem849 on July 15, 2009 at 17:05:18:
There is a bolt used to lock out 5th gear. It is located on top of the transmission case, between the base of the gearshift lever & the pedestal for the gas tank, in a countersunk hole. remove the bolt & replace it with a 3/8" x 3/4" bolt. You'll then have fifth gear. It might add a dollar or two to the value of the tractor. Most all of the steel converts had that bolt removed a long time ago & it should be an IH dot bolt. - Mike
