Re: How did they lock out 5th gear in the steel wheel tra...
Posted by athol carr on July 15, 2009 at 17:29:18 from (132.181.71.211):
In Reply to: How did they lock out 5th gear in the steel wheel tractors? posted by sflem849 on July 15, 2009 at 17:05:18:
There is a machine bolt in the top of the transmission case ahead, and to the left, of the gear-shift lever that prevents the shifter from engaging 5th gear (straight through drive). To allow 5th gear they just put in a shorter machine bolt that doesn't stop the shifeter going forward to engage 5th gear. The tractors always had the 5th gear, just if you had steel wheels you couldn't use it.
