Posted by counterclockwise on July 15, 2009 at 19:11:34 from (207.241.137.116):
Does anyone know the size and type of socket/bit that it takes to remove the counter weights from the crank on an 886 with a D358 engine. A 10mm bolt head fits into the recess but feels loose. It needs to be 12 points, but is it double hex or triple square? I understand there is a difference in the two. I need to find and order one and would like to come up with the correct tool without ordering two or three times. Thanks
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
