Re: How did they lock out 5th gear in the steel wheel tra...
Posted by steve il on July 15, 2009 at 19:46:53 from (99.196.174.11):
In Reply to: How did they lock out 5th gear in the steel wheel tractors? posted by bkpigs on July 15, 2009 at 17:05:18:
usetabesteve said: (quoted from post at 03:31:02 07/16/09) Your two problems might be related. That sloppy shifter might not be pushing the rod far enough to engage fifth gear. Fifth gear is actually a misnomer since fifth is direct drive and the shafts are coupled.
i think theres a type of pilot bearing where the two shafts couple together for 5th gear. i know if it is bad 5th will only grind or it will jump out of gear.
