Re: Timing my H with a light
Posted by Bob M on July 16, 2009 at 04:53:04 from (151.190.254.108):
In Reply to: Timing my H with a light posted by Mr. Mayor on July 15, 2009 at 20:26:15:
Expanding on Hal's advice below, once you get the timing at slow idle set at TDC gradually run the RPM's up while watching the timing. It should advance to 35 - 40 deg BTDC before the engine reaches full RPM.
If it does not the centrifugal advance (inside the distributor) needs attention.
