Re: 340 head rebuild questions
Posted by El Toro on July 16, 2009 at 06:57:34 from (205.188.116.73):
In Reply to: 340 head rebuild questions posted by mattofvinings on July 15, 2009 at 18:53:40:
You can buy a complete valve kit off this forum that includes new valves, guides & springs. It includes valve rotators if they're used on your engine. They're under engine parts that's under
"Marketplace".
You should have your local auto machine shop to do the installation. They can remove the old guides and install the new guides & ream them for
clearance after measuring the new valves. Then they can grind the valve seats. They should magn-flux the head for any cracks too & check the head for flatness. Hal
