Ive made one up from an old softball bat before, but I had to tape the pieces of the old together to make a template for it.
That failing if you wrote down the too-long and the too-short dimensions then you at least have a starting place. Heaven forbid that a TSC might actually have a mower part, but that's one possible source.
Still a model # would be helpful.
My Model 21 (made for As and Cs) uses a fairly common one, IH part #M22184
1-1/8" front to back x 1-1/2" high x 35-3/4" long
On the cam end, a slot 6-3/4" long centered and cut top-to-bottom and four holes front-to-back starting 1" in from the end and then every 1-1/2" (use the holes on the cam to mark the holes for drilling on the arm)
On the knife end, the large hole drilled in from the end to take the spring on the knife-head clamp, and four holes front-to-back starting at 2" in then every 1-1/4" (best to fit the spring into the large hole and then mark the other four holes for drilling)
If that length and description is about what you had, you could fab one from that or have CaseIH send you one.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
