Re: First time here manifold
Posted by Janicholson on July 16, 2009 at 12:54:49 from (199.17.6.60):
In Reply to: First time here manifold posted by MN Jerry on July 15, 2009 at 21:49:52:
They were painted with the hood off and the distributor cap steering wheel rim gauges, axles, serial plate,and generator spec plate taped up. Hoses and belts were painted as much as got on them! So I would do as JJ indicates, and get it running first, even work it a little to reseat the rings and see how much additional repair is needed. Best of luck, JimN
