The bypass wire causes the tests to be invalid due to the voltage coming to the fault from both sides. One other thing, if the bypass allowed the system to work some, and charge some, and discharge some, the fault may not actually show up as it could if the fault had not been stressed by the current going through it. I would definitely remove and clean each connection, then use a bit of silicone grease to reassemble the clean connections. But clean is a must. The jumper wire is like bypass surgery. Not as good as unclogged arteries, and might give a false sense of wellness. It (in this case) is possible to repair the original arteries. The worst case is that the bypass bypasses the amp gauge, and could result in runaway voltage from the alternator melting and burning the alternator and wiring as well. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
