Two real trouble spots: If the worm bearings are bad/loose check this. Turn the wheel to the right till the tires just start to turn on the ground. Have someone hold it there against the turning effort. Use a magic marker to mark the shaft around where it enters the box and disappears. Turn the wheel the other way until the wheels again begin to turn on the ground keep going till the mark is back at the same place. Look carefully at where you made the mark. The mark should still be very close if not at the same place you made it. If it is moved out any, the bearings are worn, or out of adjustment in the Worm. The big nut on the far end can tighten them, but id worn, it will bind and not do well. The shaft must turn easily if the front wheels are off of the ground. The steering arm under the front can also be loose on the main shaft. It is either a tapered square shank, or a taper with woodruff keys. These can be partially sheared, or augered out sockets. Replacing with larger Keys is possible to save the existing parts. Machine shop, or deft touch with a Dremel Grinder. THe square ones need to be looked at to see where the wear is and may need to have a new part or two to fix it correctly. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
