Re: Farmall H M Wide Front Bushing
Posted by gene bender on July 16, 2009 at 19:00:50 from (67.55.226.69):
In Reply to: Farmall H M Wide Front Bushing posted by Andy Motteberg on July 15, 2009 at 18:04:08:
When you remove the pin check as it will be a different size where the bushings go and samller in between. Thats the way the pins are on the A series. The bushings shouldnt be that hard to replace and anyone with some brass and a lathe coule make them but you should be able to get new ones from anyone who handles that sort of stuff.
