Re: Super M with MW clutch
Posted by D Slater on July 16, 2009 at 20:10:01 from (72.65.147.90):
In Reply to: Re: Super M with MW clutch posted by GeneMO on July 16, 2009 at 19:30:52:
The bull pinions can be removed on IH disc brake tractors without removing the carrier housing. Several years since I messed with a SM one but pretty sure when he gets down to unbolting the adapter plate thats used to mount outside housing , the one that bolts to brake cover holes on a band brake M. That plate is what holds the bull pinion gear in on a disc brake tractor. They used a band brake on left like a regular M on there super set up. Do remember for sure removing and installing SM units from the outside.
