Posted by Larry in CO on July 16, 2009 at 23:37:19 from (32.97.110.63):
In Reply to: Rails posted by MN Jerry on July 16, 2009 at 20:53:40:
You know, Andy has some pretty good advice and I agree that you can take one frame rail off at a time. However, I will go a step further and recommend blocking the tractor up under the torque tube and also blocking under the front bolster. That bolster is HEAVY and could, if not supported, twist the remaining frame rail. Also, if it twists, it could put the fan thru the radiator or tweak the radiator where the steering shaft goes thru it, or even ruin the one rail that is still on the tractor. Hope this helps. Larry
