Re: Manifold
Posted by John G. Hasler on July 17, 2009 at 05:39:33 from (174.124.18.71):
In Reply to: Re: Manifold posted by MN Jerry on July 16, 2009 at 21:52:25:
You don"t need to get it to fire to check for spark and compression. If it has both it will fire when it gets fuel. Check for spark in the obvious way. Since you have the manifold off you should be able to check for compression by putting your hand over each exhaust port in turn while cranking. That will tell you as much or more than getting it to fire would.
