Posted by Theman on July 17, 2009 at 13:16:54 from (63.107.135.35):
In Reply to: H and the mesh gear posted by Thomas Keiber on July 17, 2009 at 11:41:33:
The tractor doesn't have to be split to remove either the top gear - or the one on the countersaft for that matter. Search the archives or follow your repair (service) manual for removing the pressure plate and drive shaft. The constant mesh gear is part of the transmission input shaft cage assembly which comes out of the front of the transmission case. While you are at it, carefully check the pilot bearing on the front of the sliding gear (top) shaft. Also, replace any worn or rough bearings in the housing and replace the seal if you even think it might leak in the next ten years. Gaskets for this were still available from Case/IH as of last year.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
