In the floor of box near front and if its a IH box there's a channel or sunk place with two 5/8 diameter bolts, at rear inside corners is 2 more smaller bolts. If the center bolt at rear has battery cable on it, cable or it may need removed. Bolt goes all the way through top cover. Its common for the bolt heads to be deteriated from acid and moisture. If box is junk I cut it off above floor, clean around bolts and weld a nut on the bolt heads if needed.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
