Re: 340U - C135 interesting base engine problem
Posted by mattofvinings on July 17, 2009 at 17:49:19 from (198.208.159.20):
In Reply to: 340U - C135 interesting base engine problem posted by mattofvinings on July 17, 2009 at 09:21:35:
I'll post some more pictures when I get back.
My conclusion at the time was that the crank and distributor/governor gear are OK to run some more.
If not I have another good/used crank with a few surface rust spots on the gear but not bad enough to worry about.
