Re: Seals for M transmission input shaft and counter
Posted by CNKS on July 17, 2009 at 19:13:59 from (216.144.104.128):
In Reply to: Seals for M transmission input shaft and counter posted by Trapman on July 17, 2009 at 19:05:34:
Should not be a problem -- NAPA can cross the numbers for you as can any good seal/bearing place. They may have to order them which should only take a day.
