If it is pretty clean, it should break loose if given a chance. Get it in the open, and start it in gear 2nd, or 3rd. It will start to move as soon as the starter is engaged, so be careful (if a crank start, do not do this).... If a crank start, put it in high gear, brakes On or wheels blocked, and keep the ignition OFF. Then use a bit of force on the crank (maybe as much as 100lbs hanging on the crank handle) This will turn on the disk, and free it hopefully. If it has a starter hole it might have a ring gear that could be pried on with a pinch bar to assist in rotation while in high gear. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
