The orifice in your safety/pressure-control valve block is plugged. Your system is consequently continuously loaded and putting that load on the tractor engine. When you move one of the control valve handles you give the hydraulic fluid somewhere to go (to the cylinder controlled by that valve), rather than forcing it to go through the high-pressure safety valve.
This is a pretty common problem for these systems. You'll need to pull the valve block and clean it, especially the orifice in the control circuit. This problem may mean your entire hydraulic system needs to be cleaned out, also.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
