Re: Super M waterpump
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bob M on April 16, 2000 at 09:15:45 from (205.188.198.184):
In Reply to: Super M waterpump posted by Drew on April 15, 2000 at 20:37:00:
Drew - So long as the water pump is not leaking coolant, the seal is OK. (Pump seal is completely independent of the pulley bearings - is located out in front of the fan blades).
Possible causes for running hot: 1 - Thermostat is sticking partially closed. 2 - Radiator water passages clogged up with scale. 3 - Temp gage is out of whack (unlikely but it does happen....)
Suggest beginning by draining the coolant, inspecting the radiator core for junk, and while radiator is empty, putting in a new thermostat.
Post A Followup
: Re: Re: Super M waterpump
