If you decide to replace/repair your injectors you should hit up your local yellowpages. Chances are there is a diesel repair shop somewhere nearby (nearest larger town etc.). Normally you'd have your old injectors repaired (new nozzles installed, cleaned, reset, and tested).
If you need to ask the last question then yes you should seek professional help with rebuilding your injectors.
Finally, have you been through a proper troubleshooting procedure before starting to replace parts? Sam
