Posted by CoopertownBob on July 18, 2009 at 15:11:48 from (74.51.5.11):
In Reply to: Farmall M puller posted by cory smith on July 17, 2009 at 18:46:32:
First, insure you are not having a fuel feed problem by bypassing your fuel line setup and using a line run from a plastic bottle to the carb. Just cut a hole in the side of the bottle almost at the bottom and silicon some fuel line into it. Hook other end to carb fuel inlet and be sure to hold the bottle higher than the carb. If it runs fine like this, you need to change the route of your fuel line or maybe it or your filter is clogged, or maybe they are just not big enough to handle the fuel requirements. If it still has the trouble running that way, then you have eliminated fuel flow issues. Time to try something else.
Try setting your initial timing at idle to dead 0, then leave the lock down bolt loose while you try adding throttle. Twist distributor to move timing up or down till it smooths out. If you find it will run just fine when advanced or retarded severely, then you have the distributor in one tooth off. Either pull and reinstall distributor correctly, or just move each plug wire up to the next hole and don't worry about it. The only other thing is it could have too much advance built into the distributor. You'll need to ask the person who rebuilt it for you how much they put in, or if they say they left it stock, then it is 40 degrees worth of advance.
If neither of the above work, let me know and I'll give you some more suggestions.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
