Re: Generator vs Alternator
Posted by JMOR on July 18, 2009 at 15:38:27 from (72.181.158.237):
In Reply to: Generator vs Alternator posted by FarmallZach on July 18, 2009 at 06:12:05:
Owen Aaland said: (quoted from post at 17:18:42 07/18/09)
JMOR said: (quoted from post at 07:27:19 07/18/09) There might not have been from the factory, but 6v alternators are sure available aftermarket, even positive ground. They look just like the factory 12v/neg gnd, but use different reg & diode sets.
To change a 10SI alternator to six volts negative ground, all you have to do is replace the regulator. If you want to go from negative ground to positive ground you have to change the diodes.
Yep! You got it.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
