Re: 1086 problem, please help
Posted by Mazemeister on July 18, 2009 at 17:25:58 from (24.188.81.230):
In Reply to: 1086 problem, please help posted by Pacer 54 on July 17, 2009 at 20:31:25:
the loss of hydraulics and the sound suggests stripped IPTO shaft/pressure plate. See posts below.
that wouldn't usually make an oil leak though... you sure it's not hyd oil?
if it is lube oil, about the only place it could leak would be the rear crank seal. got to pull the flywheel, kind of a pain to get the old seal out, pretty easy to put the new one in. a new one would come with a wear sleeve too.
