It is not getting sensing (control) voltage. I do not know what it is hooked to, or how, but it is not self regulating, all alternators depend on a connection to a battery (or other reference voltage) to control the output. Google Nippondenso alternator images, then choose the one you have and see if you can get wiring diagram for it. Just plain Google will also get there, Google Nippondenso Alternator wiring. JimN
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
