We have 12.75 V when the tractor is off at the battery. When we run the tractor it reads on a tester that we have over 15v BUT the guage is pegged to the charge side. We tried another guage and it acted the same way...pegged. We tested the regulator using a test light and the battery and we had continuity. When we disconnect one wire from the regulator while the tractor is running the guage reads (what we feel) is a normal discharge rate. As soon as that wire is replaced the needle is pegged and you can hear a slight laboring of the engine. Any other thoughts or questions? I will google your above selection.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
