Re: 966 ta slipping
Posted by RickB on July 19, 2009 at 03:29:21 from (205.231.147.23):
In Reply to: 966 ta slipping posted by Kurt Gagnow on July 18, 2009 at 23:11:22:
It could be the main clutch, if something isn't right such as the flywheel step dimension. Or it could be the TA is junk. If the main clutch is OK and the TA slips in both TA and Direct, you have a bad sprag AND an oil pressure/Direct Drive clutch pack problem. If the main clutch and TA sprag are good, it will drive in TA mode even with no hydraulic pressure from the MCV pump.
