Re: Super A starting problem
Posted by clean John on July 19, 2009 at 16:23:19 from (216.228.193.130):
In Reply to: Super A starting problem posted by aquanosis on July 19, 2009 at 14:55:58:
Did you check to see if the starter is stuck? Put er in high gear and rock her with the hind wheel if its stuck shud hear it release then try it. Like the other posts say cud be bad connections. I have that problem with the 350 if the battery gets low (sticking)Needs new bendix drive.
