Re: TV AND ANY OTHERS
Posted by mattofvinings on July 19, 2009 at 17:53:01 from (67.142.161.33):
In Reply to: TV AND ANY OTHERS posted by lenray on July 19, 2009 at 17:45:06:
Sounds like the contact is buggered in the 3rd position (momentary or spring-return) of the start switch and so you are just barely making the contact going (presumably) clockwise, then the contact makes strongly going counterclockwise just for a second as you wipe by on the way to off.
A starter push button is not a big deal, just allow it to be energized in the 2nd position only and wire it to do the same electrical job as the 3rd momentary position.
....if these abstractions are making sense.
