Re: TV AND ANY OTHERS
Posted by old on July 19, 2009 at 18:14:17 from (4.245.5.45):
In Reply to: TV AND ANY OTHERS posted by lenray on July 19, 2009 at 17:45:06:
Seen that happen before. If it is set up to switch around the ballast resister if it has one that is there is a problem in the wiring there. So tractors, cars and truck are set up so that when in the start position the ballast resister is taken out of the system and that in turn gives a stronger spark for starting but if a wire brakes etc or the switch goes bad you end up with no spark when turning the engine over so when you let the ket loose from cranking it starts because it has spark
