Re: how to change a farmall h from 6 volt to 12
Posted by HUD 1206 on July 19, 2009 at 21:22:05 from (69.66.197.149):
In Reply to: how to change a farmall h from 6 volt to 12 posted by farmallboy1566puller on July 19, 2009 at 20:30:35:
Its pretty easy accept getting the most common and I think easist to use alt. the delco 10si under the hood and still have room to swing it over to tighten your belt . I read on here about using a smaller case alt. off a datsun car but I havent done on that way I built a idler arm to tighten the belt after that you need a12v battery a resister to put in the power wire to the coil change all lamps to 12v if your going to use lights also switch battery cables to neg ground dont need to do anything with the starter there will be a little fab work on the gen. mounts to get alt. in whole thing if you do it yourself 150-200bucks and a evening in the shop maybe less also put a diode harness on the alt. to keep from back feeding your ingnition ( tractor wont shut off sometimes if you dont under 10$ at auto supply store
