Re: AXEL SEAL RELACEMENT
Posted by Owen Aaland on July 19, 2009 at 21:42:13 from (198.70.47.142):
In Reply to: AXEL SEAL RELACEMENT posted by LONEWOLFF on July 19, 2009 at 20:29:45:
There should be two "U" shaped pieces bolted on one of the wheels. That is the tool to get the wedge locks loose. The wedge bolt uses a 12 point socket to turn.
If the seal is leaking there is a very good chance that the bearings are loose. They are originally assembled in a preloaded condition. If they are loose you have bearing problems. Just changing the seal is not going to do you much good.
