Re: how to change a farmall h from 6 volt to 12
Posted by soybeanjoe on July 19, 2009 at 21:46:16 from (66.213.171.108):
In Reply to: how to change a farmall h from 6 volt to 12 posted by farmallboy1566puller on July 19, 2009 at 20:30:35:
Find a good automotive electric repair shop & have them convert the H's generator over to 12v, it can even be changed to neg. ground if you want. I have had a couple generators off of an M & a SMTA done this way. Wasn't expensive, guy didn't charge me for one & $35 for the other one. The one he charged for needed some work done to it.
Nice thing about using the original generator is that you don't have to mess around making / altering brackets & it looks original if you are in to correctness. Only thing you will need to do is flip the wires on the amp meter if you switch to neg ground or it will show a discharge when charging.
