Re: 1086 problem, please help
Posted by Owen Aaland on July 19, 2009 at 21:48:35 from (198.70.47.142):
In Reply to: 1086 problem, please help posted by Pacer 54 on July 17, 2009 at 20:31:25:
It is not the lease bit unusual for transmission oil to leak out when the PTO splines fail. There is a seal inside that gear which has the splines worn off. As it slips in the pressure plate it is wiggled around the oil will come past the seal.
You will need to resurface the flywheel when you replace the clutch. Once the flywheel is off you can see if the rear crankshaft seal is leaking.
