Re: 40' Farmall A Narrow Front?
Posted by gene bender on July 20, 2009 at 08:34:25 from (67.55.226.69):
In Reply to: 40' Farmall A Narrow Front? posted by Joe Joiner on July 20, 2009 at 08:05:13:
You can put the B steering sector on the A then it would be tricycle front. Now measure the diff housing on the drivers side. If it measures 18in that would be an A. If it measures 22in then it is probably a B with left side of an A. check the serial# on the block and on the seat bracket to see what the prefix reads. FAA is an A. FAB would be the B.
